dcdman67
Active Member
Hi all. I just rebuilt my 1920 and I am having some issues with the fast idle cam. I have reassembled and reinstalled the carb. Whenever I hit the gas on the car, the cam does not return back to the second step, and instead sits on the first step at a very high idle. The cam has a ton of play in it. Do I need to bend the rod so that there is no play?
Also, I am having a hard time starting the car without starter fluid. Something seems to be amiss.
Any help is appreciated!
