S SuperStock Well-Known Member Joined Aug 4, 2009 Messages 463 Reaction score 24 Location Northern Virginia Rating - 100% 6 0 0 Aug 8, 2015 #1 Contact seller Early type ball-and-trunnion drive-shaft. Need rebuild. $25. Prefer pick up.
cosgig MoBro Inc. FABO Gold Member Joined Jul 20, 2008 Messages 12,369 Reaction score 6,215 Location Pinckney, Michigan Rating - 100% 56 0 0 Aug 9, 2015 #2 That my friend is a 63-65 only! In 66 they had a front slip tube and a U-joint! Hope this helps with your sale! Geof
S SuperStock Well-Known Member Joined Aug 4, 2009 Messages 463 Reaction score 24 Location Northern Virginia Rating - 100% 6 0 0 Aug 9, 2015 #3 cosgig said: That my friend is a 63-65 only! In 66 they had a front slip tube and a U-joint! Hope this helps with your sale! Geof Click to expand... Ok thank you. Have some parts need identify as well, I'd much appreciated you can ID them. Thread here: http://www.forabodiesonly.com/mopar/showthread.php?t=323354
wsuwrhr The Masheenist. Joined Jul 20, 2015 Messages 105 Reaction score 52 Location Alta Loma Rating - 0% 0 0 0 Aug 9, 2015 #4 cosgig said: That my friend is a 63-65 only! In 66 they had a front slip tube and a U-joint! Hope this helps with your sale! Geof Click to expand... All truth. Chop the driveshaft off a a few inches past the "neck up" to the shaft and I am interested in that piece. The rear section can be made anywhere. The front section is where it is at. You interested or able to do that? Brian
S SuperStock Well-Known Member Joined Aug 4, 2009 Messages 463 Reaction score 24 Location Northern Virginia Rating - 100% 6 0 0 Sep 17, 2015 #5 20, will ship
Jkirk Well-Known Member Joined Oct 5, 2009 Messages 245 Reaction score 42 Location Knoxville Rating - 100% 1 0 0 Nov 29, 2015 #6 Do you still have?
S SuperStock Well-Known Member Joined Aug 4, 2009 Messages 463 Reaction score 24 Location Northern Virginia Rating - 100% 6 0 0 Nov 29, 2015 #7 Im rebuilding it, will put back for sale later.
