BillGrissom
Lock cylinder and retaining clip for door lock on driver's side. Two dents on the stainless cover. A good locksmith can remove the cover and tap those out, plus polish the cover. I doubt this could be changed to a right-side lock since the arm is riveted on. Sacramento, CA (Arden), home most days. I know no cheap way to ship. You can tell me your preference, otherwise probably USPS small box (~$10).
I got this for my 1965 Dart since it has the same keyhole in the door, but then found that a 1965 key doesn't slide in since different slots. Research found the 1964 key is the same as 1965, so this is for 1963 only. I don't have a key. I don't see an easy way to remove the pin cover, as in later locks. It appears to be a stainless cover staked into the housing. Surely an experienced auto locksmith must know how and hopefully would have enough spare pins to rekey to your key. $20 + shipping, or happy to trade for a 1965 driver's lock if you need to go the other way.
