Mineallmine
A little more progress. Still waiting on shrinking disc to show up to do the needed work on rear of roof before putting car back on its wheels so I decided to start on the inside of the car floor while it was still at a nice level to work on. got the heater box rebuilt and the replacement drivers vent box soaking in PB blaster to free up one stuck pivot. Flushed out the heater core (lots of muddy crap came out) until only clean water came out. Has really good flow so I'm happy with that.
Cleaned up the drivers floor down to bare metal to remove the surface rust in the front floor pan. Only found one tiny pin hole so I'm happy with that. Bad thing is after welding I will have to touch up the bottom of the car again. Not a big deal but didn't see that one coming. Primed floor with etching primer and once the entire floor is finished I can hit it with epoxy or hi-build and then a coat of paint. Not sure if I'm going to go body color or just a good sealing coat as it will be under the carpet and this is after all going to be a driver, not a show car. also looking at adding sound deadening so paint really will never be seen again. Just want a nice layer of corrosion protection. The body is nice and clean and want to keep it that way.
Next week I hope to get the body outside and use my wet sandblaster to tape off and blast the engine bay. Then a good cleaning and drying and a coat of etching primer to protect it from flash rust before I can get it painted.
