Mineallmine
Has anyone with a 2 door post car that has bought new car whiskers noticed a problem with fitment?
I just installed the glass runs on the driver side of my 2 door post dart and went to install the new car whiskers but the front door outer doesn't fit. The inner is fine as the door has multiple slots to fit to, but the outer is the same (all 4 are the same) and the clip closest to the vent window has no location to go into. There is one there but it is a good inch out of location.
I went on line to look and it appears the kits I see look the same as mine. I was hoping maybe I got the wrong kit or a mix up with 4 inners.
Also, was there a gap between the whiskers and the glass? There appears to be a gap on both the inside and outside when installed. I would have thought they should touch the glass.
