first of all i would like to thank everone that has commented and given me great ideas for my turbo build on my slant 6 your help has made it alot simpler for me but i ran into a little speed bump here what i have the timing is set at 20*, the fuel jet is #64 the stock fuel jet has #56 stamped on it, and i installed a wideband sensor to see if its running to lean, all the vacuum that goes to the blow off valve, and wastegate our mounted to the itake manifold see in pic . this is what going on having the car parked if i rev the engine and let go of the trottle it shuts off it will not go to a idle , if i take the bonnet of and let the carb be open with no bonnet on and rev it, it will go back to a great idle, but like this it will not get boost. when i drive it down the street being careful with it and i give it a little gas it will start to boost read boost 5 psi but it hesitates and will start to back off and it not even with the trottle all the way open and again ones i let go of the trottle coming to a stop sign it will shut off. what do you think it is i have my thinking cap on but it might be backward lol help me out here here some updated pic with some changes here my number if you would like to call and help me out 619-888-7084
