Mineallmine
I am getting near to the finish line on my 1963 Dart rebuild and went to put the redone steering column in and ran into a snag. The gasket for the firewall that I ordered that stated for 1963-66 dart is incorrect. The one I got is from DMT, which is usually good parts has only 3 holes while mine has 4.
Was there 2 different styles of columns in these cars? Has anyone else run into this issue and if so what did you do for a firewall seal. I have searched with no luck to find a match.
I am considering making my own at this point. I have ordered a roll of neoprene sponge foam to make my own. It is 1/8" thick which seems about the same as the gasket I recieved. Only difference is that the roll I ordered is black and the original was white. That's not a big deal to me, as long as it does the job I need it to do. Do you think this is a suitable material for this application or does anyone have any suggestions on a better material?
Thanks
Thanks
