[SOLD] 1964-66 Interior A Pillar Trim
skylines225
Long Beach
Looking for a set of interior windshield A pillar trim for either 1964 65 or 66 Plymouth Barracuda or Valiant. Driver quality if available. I'm beginning to think the front door leaks have been due to the missing trim. Thank you!
Photos are for reference only. I would take pictures of my own car, but I'm missing the parts.
I've come across a few in poor condition, or with pieces missing. If anyone has this trim available, I'm still interested. Thanks!
In stock and ready to ship......
CF-656APL Left A-pillar moulding $ 79.00 ea
CF-656APR Right A-pilllar moulding $ 79.00 ea
CF-656APP Pair of A-pillar moldings $149.00 pr.
That's what I've gathered, that's why most are broken or gone. I think the 64 metal ones also require a trim piece that attaches the the top of the dash
I might have a set based upon your photo but can't remember if they're the same without looking at mine. Unfortunately I'm in Norway currently and will be home tomorrow. Can check probably Monday after doing some jet lag recovery.
The trim plastic pillar covers.....1966 Valiant Signet is different than Barracuda....
There is a small piece missing where the pencil is pointing. PM me if interested.
Cheers - Mike
Ok, I have a Black Set from a 66 Barracuda. They are dirty but can be cleaned and polished.
The drivers side has a small chip where the lower screw holds it in but would not be seen as the screw would hide it.
The passenger side has a crack almost all the way across the bottom and around the lower hole. If you had nothing at all this set would be an ok driver set. I spread the crack apart a bit so it could be seen but doesn't show otherwise.
So are 66 cuda plastic or metal?
I just pulled mine to repaint and put in new gasket.
Clarification:
When I pulled apart the interior trim I found plastic on the A pillars and metal across the top above door and rear window and also down the rear window. I would of thought they would be all same material?
