I was wondering if anyone had a list or link to decode the ABC and 123 options on a 64 fender tag. The car is a 64 dodge 880 custom, built at the Jefferson plant.
I do not know of anything definitive on the early cars. I use several resources (and some guess work) to do the early tags. Post a good clear picture of it - i'll see if I can help... You can also bypass the vague fender tag and order the build card from Chrysler Historical. This will give you all the information you should need.
Attached is a picture of the fender tag, any info you have would be great. I have been looking all over for some sort of decoder or list of options for 64, but haven't found anything yet and the 65 stuff doesn't seem to match up.
