[WANTED] 1964 Fury Bulkhead connector
Someone really need to re-pop these bulkhead connectors.....Good Luck in your hunt....
Is it the connector body, or the electrical terminals you need? Those terminals ARE available through NAPA
the U pull it in El Paso I frequent has a 63 Belvedere. Not sure if same as what you need - just putting it out there.
I do not know if the 63 is the same or not.
I have a couple of leads on connectors. Just waiting on photos to make sure they are what we need.
Thanks for the input,
Herb
