1964 plymouth valiant recommended rim for 245s in the back
64whiteghost
Whatsup guys. Today is a good day. Rear end is installed and brakes also.
I have my measurements. They are as follows: from front of the face of the disc brakes here are the numbers
5 1/4 to lip
6 3/8 to leaf spring
3 1/2 top of inside wheel well
I want to run 245s on the back. What size rim 15 x what ? and what backspacing would allow me to fit a 245 on my rear ?
6" is about the narrowest you can get away with 245's so i'd start there with a eye toward backspace. like we all stated before, the outer wheel lip and how the quarter pinches in is where you're going to find the limiting factors.
i would think a 7 or 8 would allow the tire to sit a little more "square" and not bulge out the sidewall as much, but i don't know if you've got the real estate for that with an off the shelf rim.
5 1/4 to lip
I want to run 245s on the back. What size rim would work the best for me ?
Looks good. Ya, that rear disc will throw you off because it's not the same as my 66 with 10" drum brakes. For my Swinger, I started with a wheel that fit even though it was too narrow. I knew I couldn't add a inch of backspace but I wanted to go from a 5.5-7" if possible. I had room for 1/2" on the inside and a bit more than a inch on the outside. 15x7 with 4.25" backspace.
So your thinking 15x7 with 4.25 back spacing ? for the pictures i have up
