gtxdude
This car has a mid 80's rebuilt 318 four barrel with push button transmission, you can drive this car any where. Has mopar electronic ignition, recored radiator, no p.s or p.b. tranny leaks a little probably seal not to bad. This is a older restoration, I would call it a 20 footer. Very sharp car going down the road, get a lot of compliments on it. It no longer has a show car finish, when you get up close and look at car you see the paint flaws and chips, no rust! Floors and trunk are solid. Also rear quarters are no longer as straight as they should be for show car, paint still looks shiny and nice, like I said a 20 footer. Interior is cloth and very good shape probably done when car was restored, I might have done it differently but looks good with car with it's color. Has power top that works and is in excellent shape, mechanically sound. Everything on dash works except lighter, speedometer is a little jumpy but works, gas gauge works. Just replaced heater core, kicks out a lot of heat for that fall cruising. Head lights and tail lights work. Have put on over 1500 miles this summer and has run great. Cannot verify mileage, please review photos and let me know if you have any questions. There are some dings and dents in bumpers and trim it is not perfect. I allways feel it's best if your serious to look at car or have someone look at it for you.
$8900 or close to it, St. Michael, MN 55376
