1964 Valiant V200 wagon parting out
jysnflem
Rating - 0%
0   0   0
Here some pieces that are going forsale. If you are interested send me your e-mail and I'll send you a picture of that item only. Jayson
1.Plymouth hood emblem with some pitting $15.00
2.Pushbutton shifter bezel with no cracks $20
3.Slant 6 air cleaner assembly $30
4.Valiant V200 dash trim 3pcs with Heater switch, and temp controls. $40
5.Pushbutton shifter missing spring for park lever,some buttons don't stay pushed. $20
6.Jack assembly $45
7.Pushbuttons shifter cable with no cracks 41" long. $70
8. Instrument cluster speedo doesn't turn,unknown if gages work has no cracks.$25
Hey jysnflem
Do you still have the clips the hole the heater cables to the heater box?
Bear
Taillights are gone already and I'm saving the tailgate and the rest of the car is rusted pretty bad. Might be able to cut some small patch panels. PM me what body parts you need. I just brought the car home to remove more parts so let me know. Jayson
any body parts?? Tail gate , Tail Lights
Here some pieces remaining that are still forsale. If you are interested send me your e-mail and I'll send you a picture of that item only. Jayson
1.Plymouth hood emblem with some pitting $10.00
2.Pushbutton shifter bezel with no cracks $15.00
5.Pushbuttons shifter cable with no cracks 41" long. $70
6. 1964 trunion driveshaft for slant six $25.00.
7. 1964 Valiant underdash wiring harness $20.00
8. 1964 slant six throttle rod and kickdown linkage. $25.00
Also have set of 4 13" hubcaps. $15.00. Jayson
I need a slant six pushbutton converter. mine is bad. Im not sure if your tearing down that far but mine is locked up. Thanks
6.Jack assembly $45
I will take the air cleaner...do you have the gas cap/taillight lens/passing gear linkage 1964 dart let me know
