1965 904 Transmission Normal Operation?
Transmission and Drivetrain Tech
  1. barracuda1965
    barracuda1965 Barracuda1965 Formula S
    3
    2
    Mar 31, 2006
    Minnesota
    Local Time:
    6:56 PM
    I've had my 65 Barracuda Formula S together and running for a number of years now but still wonder if the transmission operation is normal. It is a stock 65 904 cable shift trans that shifts normally except for down shifts. It will not downshift from 3rd to 2nd gear under part throttle. It will drop all the was to 1st when floored. First off I have adjusted the kickdown to stock specification and fine tuned it up and down.. changes nothing. It will manually shift to 2nd with the floor shift.
    Somewhere I remember reading that this transmission does not downshift to second by design. True or false?
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,627
    3206
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    7:56 PM
    I believe that part throttle operation was not adopted until 71 or so. I don’t think it can be adapted in these earlier transmissions.
    • Agree Agree x 2
    • Like Like x 1
    • Charrlie_S
      Charrlie_S Well-Known Member
      3,005
      841
      Oct 17, 2005
      Silver Springs, FL
      Local Time:
      7:56 PM
      It does not have part throttle downshift, but it should still downshift from 3rd to 2nd at full throttle above a certain speed, or 2nd to 1st at a slower speed.
      As for retrofitting part throttle downshift, I know it can be done on 66 and later transmissions, but don't know if it can be done on the cable shift trans.
    • challenger57
      challenger57 cuda57
      207
      15
      Sep 21, 2007
      york, pa.
      Local Time:
      6:56 PM
    • challenger57
      challenger57 cuda57
      207
      15
      Sep 21, 2007
      york, pa.
      Local Time:
      6:56 PM
      I had a cable shift in my 65 also before changing to a 4sd manual. If left in drive it shifted normal, i don't ever remember it down shifting to a lower gear while other than the gear i had it in. I still have it if any interest.
    • dibbons
      dibbons FABO Gold Member FABO Gold Member
      4,358
      2502
      Nov 6, 2009
      La Paz, B.C.S., Mexico
      Local Time:
      4:56 PM
      Can'y verify accuracy, but here it is from Wiki:
      In 1968, part-throttle downshift functionality was added to A-904 transmissions used with 6-cylinder engines. This feature permitted the transmission to shift from third to second gear in response to moderate accelerator pressure. Previously, an automatic 3-2 downshift occurred only if the driver pushed the accelerator to the floor. This change was made to maintain acceptable in-town performance with taller final-drive ratios in the rear axle — 2.76:1 rear axle gears were being furnished in applications previously equipped with 2.93:1 or 3.23:1 gearsets. Part-throttle downshift functionality was extended to V8 A-904s in 1969, and to most A-727 transmissions in 1970 to 1971.
      I have driven my parent's new 1971 Road Runner and I own a '65 Signet Convetilble and '65 Formula S all automatics. I tend to agree with the Wiki article based on my personal experience.
