1965 Barracuda
Is it power steering? Does it have a tach? I coul use the column, box, and pressure hose (I think I see the end of a hose in one of the pics...), plus wiper arms.
i will hold out hope for the wheel well moldings (not giving up) also do you have the ruber seal that goes at the bottom of the back side windows?
if they are good I meed the price on them also
Thanks Carl
Thanks Carl
I will let you know Sunday on the wheel well trim, those rear window rubbers aren't worth saving.
Thx. John for the parts,for the use of you air tools and your help.Thx. to you and your wife for the hospitality.It was a pleasure to meet you both. Peter&Tammy
It was great meeting the both of you and glad you could make it over and find plenty of parts for your project. :salute: Keep it touch!
i could use some floor sheetmetal from under the back seat from the underneath where the rear frame rails attach. I also need a spare tire bottom. Lets see, I need rear spring shackles... windshield washer pump(if working) inner door handles; matching locks, keys and ignition switch. Instrument cluster, fuse block with wiring under dash. Radio. My car is missing so much, but I am in PA.
If I were you, I'd strip the fenders, hood, front valence, deck lid, and anything you can cut out, including the rockers. Someone up north will want it. SAVE THOSE SEATS
