[FOR SALE] 1965 cuda? or valiant? hood trim
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
Left over piece from 3 yrs ago. I replaced the 65 cuda hood with a valiant hood on that project. I am not sure which this was off of!!!! Hoods are same, but seems like the trim piece was slightly different> $15 plus shipping if someone can use it
If the Valiant emblem has a notch on the bottom it is for a 65. 65 model had a release lever underneath the emblem.
The trim piece looks like early Valiant, maybe on 1/4 panel.
I remember an issue with hood latch for the hood I used. I used the valiant hood and no doubt had to use its hood emblem. As I now recall the PO had sold off the hood and fenders off said 65 cuda, and all I found worth having was the valiant pieces...This I assume will be for 65 Cuda HOOD and maybe a 64 or 66????? Just trying to find it a deserving home!!
Too many project cars under the bridge!! and bad memory!
The lower piece in pic is broken and off the Lancer road toad. NOT supposed to be there!
65 only, if it has the notch on bottom for release lever. 64 is very similar in appearance but release lever is under bottom of hood.
A 66 emblem if there is one would probably be similar to 64 emblem. 63 emblem is smaller, little different shape and one year only.
