1965 Dart GT 273 Commando 4 speed
Members Restorations
  1. Big Ben 16
    Big Ben 16 66barracudaNS
    47
    11
    Jul 22, 2017
    Middleton, Nova Scotia, Canada
    Local Time:
    7:09 AM
    Great job love your car. I've picked up a few ideas for mine especially like your door cards
  2. Oldschoolcuda
    Oldschoolcuda Early-A Body Nerd FABO Gold Member
    5,700
    4229
    Mar 24, 2008
    Suffolk,VA. - Pumpkintown,SC.
    Local Time:
    6:09 AM
    Thanks Ben. She came real close to being parted out by previous owner. Saw her potential and decided to do a budget build and save the old gal.
    Has been a fun project.
  3. Oldschoolcuda
    5,700
    4229
    Mar 24, 2008
    Local Time:
    6:09 AM
    Fabricated my spare tire well board, got pillar & roof trim installed and finally got seat belts in today.
    • Like Like x 1
    • SSVDP
      SSVDP FABO Gold Member FABO Gold Member
      5,406
      6996
      Feb 6, 2009
      Clarksville, Tn
      Local Time:
      6:09 AM
      That car is fantastic!
    • Oldschoolcuda
      5,700
      4229
      Mar 24, 2008
      Local Time:
      6:09 AM
      Thanks so much.
      Still much to do but she has come a very long way in a yr. and is now only a steering coupler rebuild away from seeing regular cruise duty and a battery disconnect switch away from going to northeast dragway for a test n tune run.
      Need to get her out of my car port work area and take some full pictures of the old girl.
      • Like Like x 1
      • Oldschoolcuda
        5,700
        4229
        Mar 24, 2008
        Local Time:
        6:09 AM
        Got steering coupler rebuilt then took her out for a nice cruise today. Finally took some better pictures out in the sun.
        Still a lot to do but she is roadworthy and definitely hauls azz.
        • Like Like x 2
        • Oldschoolcuda
          5,700
          4229
          Mar 24, 2008
          Local Time:
          6:09 AM
          Been driving her a good bit recently to work out bugs.
          Discovered fuel pump was sending 9 psi to my edelbrock carb(way to much) so installed a regulator & gauge. Huge difference now.
          Ceramic coating on headers was showing age so freshened them up with some vht flame proof and started polishing her wih sand paper to bring out patina a little more. lol.
          • Like Like x 1
          • Oldschoolcuda
            5,700
            4229
            Mar 24, 2008
            Local Time:
            6:09 AM
            Fabricated some kick panels for Dart today. They are shorter on the back than factory so my fuse-able links can be accessed without removng em.
            Just a budget hotrod but now im mulling over painting her & what color or just leaving her be.
          • 340doc
            340doc Well-Known Member
            2,692
            949
            May 8, 2010
            Hollywood Fl
            Local Time:
            6:09 AM
            Looking for the "Drool" button!
            • Like Like x 1
            • chryslerfat
              chryslerfat Well-Known Member
              13,686
              8158
              Aug 23, 2008
              Monroe,Michigan
              Local Time:
              6:09 AM
              Just blow some gold on her dry spray and sand the top corners if you like the aged look.
            • Oldschoolcuda
              5,700
              4229
              Mar 24, 2008
              Local Time:
              6:09 AM
              Finally got my homemade kick panels installed. After driving her did not like tach on steering column or line lock button on shifter. Switched to a tach under dash moved line lock tap button to steering column and just added a single oil pressure gauge as all stock gauges amazingly work. All she really needs and much less clutter.
              Going to go ahead and add carpet then interior will be basic/ but perfect for this bone rattler.lol.
            • chryslerfat
              13,686
              8158
              Aug 23, 2008
              Monroe,Michigan
              Local Time:
              6:09 AM
              You sure have made that into a fine looking fun car.
              • Thanks! Thanks! x 1
              • Agree Agree x 1
              • Oldschoolcuda
                5,700
                4229
                Mar 24, 2008
                Local Time:
                6:09 AM
                Scored a complete set of sill plates from 65 Dartman( thanks Don ).:thumbsup:
                Cleaned em up today and installed the outside plates.
                Hopefully my carpet will arrive next week and interior will be done after gettin carpet and inner sills installed.
                • Like Like x 2
                • rustyfish
                  rustyfish Member FABO Gold Member
                  1,250
                  1430
                  Sep 15, 2015
                  Shawnee, KS
                  Local Time:
                  5:09 AM
                • Oldschoolcuda
                  5,700
                  4229
                  Mar 24, 2008
                  Local Time:
                  6:09 AM
                  Waterproof panelboard (32 x 48) . My local lowes stocks them.
                  They are cut with templetes to correct size then scuffed. Mine are then coated with truck bedliner spray. Added original trim from my fubared original. They are installed with a screw holding each side at bottom.
                  Not for everyone but each one cost me only $12 in supplies.
                  • Like Like x 2
                  • rustyfish
                    1,250
                    1430
                    Sep 15, 2015
                    Shawnee, KS
                    Local Time:
                    5:09 AM
                    Thanks, looks good to me!
