[SOLD] 1965 Dodge Dart 270 $1,800
68 A
Auburn, NY
1965 Dodge Dart 270 – $1,800
273 2bbl – Block is cracked
904 automatic
7 ¼ rear
New Parts:
-Gas tank – fuel lines & fuel pump
-Master cylinder – stainless steel brake lines, wheel cylinders
-Transmission cooler lines
-alternator
-U joint
-Y pipe and pipe to muffler (from Accurate)
-Replaced front floor pans, passenger side rear pan
-Welded on a frame cap on driver side front frame rail. The rest are all solid
Interior is ok. Door panels look good except for the speaker holes cut in the fronts. Seats are rough and need new padding and covers. Following interior parts are new in box:
-Blue carpet
-Blue headliner
-Blue package tray
-Radiator was pressure tested and painted last winter – not sure if its still good, I left everything full of water and that’s why the block is cracked.
The remainder of the body is in fair condition, obviously needs some more work and paint to look good.
Auburn, NY 13021
Cash only
Thanks,
Steve
Congratulations, go to the top of this page and click on thread tools in the dark bar please and mark as sold. Thank you
