Glad to hear it arrived safe and sound - it will be perfect for your wagon!
I can't agree more with you Don! Thank you my friend!Glad to hear it arrived safe and sound - it will be perfect for your wagon!
Started with the steering column. Took off the connection for the wiring harness and pulled the turn signal switch.
The lower part of the steering column is the tricky part. Specially to take off the wires for shifting. Vent ok.
Mine's a late 65. Assembled June 26th 1965.
I need to order one! Thanks Don.Did you order a new turn signal switch from @slantsixdan rather than hope the original one doesn't break and you have to replace it
Next thing to finish up is the drivers side air outlet. It looked tired but after a good cleaning and some new paint and a new gasket it will do a good job on the car!
Yes, date coded week 21 of 1965.Top picture - is that the bottom of the dimmer switch?
Can it be different assembly line at the same plant? I know that sometimes they had problems with one supplier and got parts from another one. Can be the story in this case!Interesting! My wagon was assembled 7/19 in LA had the same PS steering column as yours but had the bolt. The Barracuda I'm parting out was assembled 3/23 in Detroit and also used the bolt.
And they have great products!Complete sets of gaskets are available from Detroit Muscle.....their ad is above.
Any update poctures on the bodywork Don?I'm doing just the opposite with my wagon - removing all the 270 side trim and welding the holes closed!
Yeah, sorry I forgot about that!!!No, i’ve Temporarily stopped on the wagon since I boughtt the 47 and now parting out the Barracuda.
Did you ever find an E Brake handle in your spare parts? Here’s the one still on the Barracuda - gotta find time to get the handle out!View attachment 1715108337
Re the E brake, it's funny! I tslked with Johan last night and he found the E brake handle gor his four door sedan. Exact as yours. Mine's different. I have ribs in mine and the hole face is towards the driver. The one you and Johan have are from 1966 and up.
Or did Chrysler used them earlier due to one bad supplier. Then one else jumped in...?
Facinating and interesting.
