1965 Dodge Dart 270
williaml
Ringwood NJ
I have a Dodge Dart that has a bolt pattern of 5 X 4 without any modifications can I put a 14" rim on. Right now the tire size is 13" X 7. I think Crager is the only one out there that has a 14" rim with a bolt pattern of 5 X 4 any help would be appreicated. The rim and tire specs have me all confused with the off-set and back spacing I'm really confused.
7 inch/4.125BS 245/60/14 on the back. 6 inch/3.375 BS 205/70/14 on the front, 8 3/4 stock spring location.
Cragar S/S 15x7 with BF Goodrich Radial T/A.
215/60-15 rear and 205/60-15 front
Apologies for the incorrect cas cap, is now replaced.
I ordered Crager SS rims 15" for the rear 14" for the front I hope I wont have any issues with the added height. I think I will be okay in the rear just dont want to change anything in the front to fit tire.
Good Morning,
Did you do anything than just but the bigger wheels and tires? The 15's fit on there with no issues? Last question....did you go with larger in the rear to fill up the wheel wells? Thank you looking to upgrade from the 13"s. Mines stock with drums front and rear.
