ObcessedwithM
Is there any thing you can bolt on to a 273 to make it have a little more power and torque?
My buddies 65 dart charger has an 8 3/4 he installed with 355's, four barrel 650, and 4-speed. It was a 273 four barrel from the factory and goes pretty good.:burnout:
I'd go Comp Cams XE256H or XE262H,
66 is solid a cam but no reason to stick with solid cam.
All you need is push rods, there aren't many small solids cams.
or skip the single 4 and I could sell you this
