Hey all, I have a few items from the 66 Barracuda I'm parting out, so I thought I'd list them here. Heres the list with a picture of each item...
Brown Dash Pad.. this came from a car with a gold interior, but the pad actually looks brown. There are a few minor cracks in the material, but overall a pretty nice pad for the money. Price is $75.00
Power Steering Floor Shifted Steering Column... Once again, gold in color. Comes without the steering wheel, although for a little extra, I'll throw that in. It's cracked where the tines meet the center. $50.00 for the column, $10.00 for the steering wheel. I also have the entire power steering setup with the pump and brackets, gearbox with pitman arm, and hose if someone is doing a change from manual to power. $100.00 for the entire setup
Bucket Seat Center Support Brackets... These weld to the floor for the inner studs of the bucket seats. I left plenty of metal for a mounting reference point, but I will trim them if need be to save on shipping. $20.00
White Interior Door Panel Set... These are all in decent shape except the passenger rear has a hole in it from a broken window mechanism, and the drivers rear backing board has some detereoration from moisture. $50.00 for the set
Insturment Cluster...This is for a 66 Cuda, and has the performance indicator and 120 speedo. All of the guages are present, although I have not tested them, and overall this is a pretty decent cluster. The bezel is in decent shape, but does have a small corner broke off around the inside of the steering column area, but is not seen once installed. There are 4 resoldered pins on the circuit boards, all 3 on the flat-3 side and one on the 6 pin cluster. This was done by the guy I bought the cluster from. He said that the pins were not broken, only loose, and that he soldered them to firm them up. Its what it is and I'm leaving them as is. $75.00 for the cluster
Thats all for the interior stuff for now. I am going to list some exterior stuff too in another thread. As usual, the buyer will pay ACTUAL shipping on these items, and if you have any questions or would like to see more pictures just message. All items are located in Michigan, near Ann Arbor if anyone wants to pick up an item. Thanks for your interest and enjoy!!! Geof
