1966 Barracuda Reproduction Tachometer - any experience
cudajames
San Jose, CA
I was wondering if anyone has any first-hand experience with Vans Auto Reproduction Tachometer for a 1966 Barracuda?
Dash Tachometer Gauge 1966 Barracuda
I would love to replace the existing performance indicator with tachometer and I am having trouble finding an OEM one.
Should you be interested I have an original tach BUT it’s in an original cluster.
Not much info to go on. I would assume that you would need the wiring and the sender that mounts in the driver side kick panel.
I removed a factory tach in my 66 Barracuda and bought one from Vans LLC. Works great. Needle is a bit off (size)from the factory tach. I sold my tach and the “box” that controls it because it would not work with HEI or Mopar electronic. That’s a points only unit. Other than that the fit and finish is good. Not 66’ barracuda perfect but so close a Chevy guy cannot tell the difference. lol!
8000 RPM! It doesn't say whether you need the tach drive or if it's independent. I assume modern electronics, so, probably independent.
