[WANTED] 1966 Barracuda trunk hinges
DesertBarracuda
Active Member
Whitewater, CA
Looking for a good set of trunk hinges for my '66 Barracuda. One of mine has been repaired (poorly) by brazing, and the other is bent slightly causing the trunk to not sit flush. Thanks.
They can be hard to find, usually they have broken pins or the bracket itself is broken. But new pins can be installed and they can be rebuilt. Not the best design or strength, good thing those trunk lids are not any heavier! I can’t remember if they are a left or right hinge or maybe they are the same for both sides...but I do know the little chrome trim pieces that screw onto them are definitely different side to side...mix them up and they break off when the trunk lid is opened all the way...sorry I don’t have any....good luck in your search
I have some, but they won't have perfect factory pins. I think all mine have replacement pins in them. Some are just big cotter pins, others some other sort of pin or bolt.
