flathead31coupe
29.5x10.5x15 slicks what has to be done to get theses to fit...and if i had a custom wheel what back spacing... thanks
I forgot to mention, if you choose to move the rear axle rearward, you might have to go to a fuel cell for clearance due to interference between the stock fuel tank and the rear axle housing. Especially if you choose to run a Dana with some of the aftermarket rear covers.For that width, you will need to at least mini tub and move springs into frame rails or go to something like ladder bars or 4 link with coil overs. For that height, you will need to move the rear axle rearward or trim the quarter panels.
Backspacing for wheels will be dependent on what width rear axle you plan to run. The below link will give you the procedure for determining what backspacing you need.
How To Measure For Proper Wheel Sizes
