Any idea where these go?
Thanks
great progress
the left most part is part of the console linkage. the rod that goes through the floor hump slides into the hole. the 2 bolts (if I remember right) bolt to the trans. that way you have a floating linkage so the shifter doesn't move with the trand/engine when you accelerate or decelerate. the other 2 parts .....I have no idea at all. i have not seen that on my dart anywhere that I know of. hopefully I don't need them since I don't have them
when you go into the thread (like
I'm doing in a reply or a start of a thread do you see the paper clip on the top of the tool bar (right next to the smiley face) click on that and a window will pop up (you have to allow popups on this site.) then a list will pop up in a separate window like this
(step 1)select browse find the picture you want to upload(do not hit upload at this time)
(step 2) click on the next row browse (repeat step 1)
(step3 ) select all the file?? are you done ok NOW hit upload.. wait for the files to show in the popup window
like this
then close the popup (says close window top right hand side in the red/maroon bar.
now you back to the message saying ok where the heck are my pictures I just uploaded... funny that you should ask. make sure where your flashing cursor is (ya know where you were typing, the flashing line) click on your mouse where you want a pic to go just click on the paper clip again and bingo there they are. now to insert them just click on and choose that pic. or insert all in a column by hitting insert all. BAM! done deal. hit preview message and you'll see you shiny new pic's in there.
edit as you like . (dang sounded hard didn't it). it's harder to explain it that do it really. after you do it the first time you'll say DUH:banghead: that's easy.
they must be of a certain size also (640x480) is about perfect for most other people to see them fully without having to scroll the screen left to see it all.
it really is easy once you do it for the first time.
now to confuse ya for sure.
you could upload your pic's to a site(flickr, photobucket ect) and use the popup window but choose the bottom button that says
"upload file from URL " then add in the website to your pics
like www.flikr.com/mypictureofmy66dart.html" or something similar
preview it and save changes
now your really done
hope this helps
