1966 dart gasser project...
flathead31coupe
indianapolis indiana
I am doing something along the same line but to a 1965 dart. What are the headers for? I cant seem to find any that will work but it looks like you have the hot set up
I used a Chassis Engineering engine crossmember in my 64 Dart 440 Clutch flight dana 60 Hedman fenderwell headers
I have added this type build to my bucket list several times only to scratch it off! ha
would have to be a wonderful toy and the build would so much fun!!! keep us informed of you progress, subscribed.
I am building a 64 Dart, 383, 4 speed, Dana 60 car.
Let's rock!!
Mike
Are you installing a A100axle and springs? When I did mine had to used truck oil pan. Because center sump hit axle .Mine is about 8 inchs over stock height rocker panel to ground is 15 inches front steer 525 borgeson box. Engine in stock location.
