[WANTED] 1966 Dart/Valiant A/T steering column and linkage
Kern Dog
Build your car to handle.
Granite Bay CA
Hey guys and gals,
I have a 65 Dart with a later 904. The prior owner installed an aftermarket floor shifter that he wants back. I want to switch to a stock appearing column shifted setup. I understand that the 1966 model A body cars are the only ones that have both a slip yoke transmission and mechanical shifter linkage.
What I need is a steering column with shift lever and every piece of linkage from column to transmission.
I am in California.
I did have one FABO member that had what I needed when I asked about this several months ago. The site update cleared all my old PMs !
Thank you to anyone who can help.
I feel a bit stupid. I didn't mention it but I need a power steering type column!
Thanks again, Greg
It was me you were talking to a few months ago about this set up. The columns are the same the steering shaft is the difference and you could use your existing 65 Ps shaft in a 66 column.
