1966 pltmouth barracuda radiator for 318
midnight cuda
Member
santa rosa
Rating - 0%
0   0   0
car is a 3 speed im putting in a 318 tommorrow as one of my birthday presents i need to buy a radiator and the engine part of my cuda is done ;) so if anyone has good shape one for sale
Pretty much ANY 22" Mopar radiator will bolt in. There are two basic configurations: 1964-1969 which has a drivers side lower hose, and 1970-up which has a passenger side lower hose. The later radiators will swap into early cars if you use the 70-up water pump. If you are using a 70-up engine, with the timing marks cast into the timing cover this may be a desirable setup. The early water pump puts the lower hose directly over the later timing marks, making them hard to see.
