Bakerlite
- Joined
- Nov 12, 2007
- Messages
- 6,431
- Reaction score
- 3,316
YepThat's a bit large, IMO.
Dang right and don't you forget it.Good to be known for something !
My 67 Dart was solid lifter, before I added 199 cubes to it.According to Hemmings, first year for hydraulic lifters is 1968, like Mike said.
Nice! You went from a Cessna to an F16!My 67 Dart was solid lifter, before I added 199 cubes to it.
Ultralight then. With a misfiring Briggs.I think Cessna was being generous lol
Then you are blind.The 270S Comp Cams I quoted earlier is a solid lifter cam. Because my understanding is this engine used a sol lifter cam....
Somebody else recommended the XE 256 cam. That is a hyd cam, 212/218 @ 050.
According to Crane Cams, to get a rough comparison of a sol to a hyd cam, you need to ADD 8-15* to the 050 duration. 8* if it is tight lash, 15* if it is wide lash.
The 270S has variable lash. If you lashed it at 0.030" lash, the duration is reduced 10*, now a 260 degree cam & a reduction in the 050 number as well. Power range listed as 1500-5500 rpm. So I do not see how it could be too big, considering what the OP is seeking.
Nope. 67 273's were solid lifter engines. Hydraulic in 68 and 69.Isn't 67 hydraulic ?
I Thought that from the 1st year 67 318 that both 273/318 were identical other than bore.
Bewy will be along in a moment to tell you that you should have just kept adding valve lash until it purred like a kitten. That dodgy trick is so 1980's... lol.We installed the 270S in our 273. 2 barrel pistons. Too much cam for the heads and compression. Stock TC and 323 SG, LD4B.
I even did a mild port job, not near enough head for that cam.
Sounds great, lol. It will get the Commando pistons in near future hopefully.
I figured that variable duration didn’t last long. Seems like there were a lot of failures involving hammering the valve train when set loose and wiping lifters out when set tight. IIRC, solid don’t work too well when they run completely out of lash. Don’t contend too well holding back combustion pressure at TDC. I’ve seen detonation go to pre ignition and wipe out a hydraulic in stout build before.Bewy will be along in a moment to tell you that you should have just kept adding valve lash until it purred like a kitten. That dodgy trick is so 1980's... lol.
http://cochise.uia.net/pkelley2/dcrvb6.zip My security software tells me there is a Trojan Horse in that website.I asked this question when building my current motor
I got lots of great advice with lots of varying views
I learnt a lot about cam timing, but i'll admit not enough.
Not enough becasue like many i build an engine once every 10 years or so,i make changes rarely, got teenage kids and a house to maintain, work a 40 hour week so i'm never in a position to try try try again, comparisons back to back are not really that possible.
i need it to be an improvement over what i had.....so i have to make the best of it
Also until its in bits and you can measure, you are not fully availed of all the facts
i found it easier to take all the suggested cams
and run them along with the measurements i had taken or had got from the manaul
in this software
it should run on old PCs xp win7 win 8 and will run, or run in, "compatibility mode" on win 10 and win 11 provided your windows allows you to install any softwre you like. not just stuff from the microsoft app store (usualy cheap lap tops and tablets are stuck with that)
it does everything for you, so you don't have to manully do the maths
discussed here
Dynamic CR
with your rod length, your stroke (rod ratio) your bore your combustion chamber CC and the deck height.... the bore of your gasket and its compressed thickness the cc of the valve relief in the piston etc.
you can plumb in the cam figures to check DCR, fill first tab, use answer from first tab in the second tab and repeat the process again in the 3rd tab
look for a cam that gives a DCR in the 8.8 to 9.1 range 9+ with good manifold and distrinbution closer to 8.8 with a crap one.
it aint a magic bullet but it gives you an idea of the cam needed to produce a motor with decent cylinder pressure, decent torque and that will run ok on the gas you intend to feed it without pinging.
the actual cam spec you come away with might be slightly off what you expect, becasue most talk in the realms of static CR and its dynamic CR that counts, but if you put in the cam figuers as specified and put the chosen cam in te motor straight up that motor will run nicely, provided that its a quality assembly, correct advance curve and decent tune
its very good if you don't want to buy anything more, have to work with what you have and just need to home in on a cam spec.
in the right hands you can use this as the centre of a build and adjust stroke rod ratio static CR etc but thats for the guys who do this every day or race rather than play at the track. But it works very well the other way as well. everything fixed (no more money to spend) apart from the cam n lifters....
its a tool to help with the math. A person builds a nice motor, not a computer program. but i sure found it a great help.
It might help in your quest.....
Dave
in this software
discussed here
Dynamic CR
look for a cam that gives a DCR in the 7.5 to 9.1 range 9 with good manifold and distrinbution, and high octane fule closer to 7.5 for a street engine running standard octane fuel. for the 8.5 to 9 range as i had upgraded carburation and nice set of headers
Dave
