1967 A833 date code plate
dadsbee
Penetang, Ontario
Is this factory??? I've googled it to death...
It sure looks like maybe it is. I've never seen one. ......and that means not one durn thing. lol
Yes it is factory all day long. 1966-1967 833 trans
just like carb tags they get tossed aside when worked on. Or torn up with repeated side cover R&R
Thanks!!!!!! !!! Everything lines up on the Forumula S then.
Engine block cast 2 27 67 and the trans 3 27 67. Car SPD 4 28 67
Haven't got in to clean the "distributor" pad to see actual engine build date. Today's job..
I’d say the trans tag was stamped and put on when they were bolting on the side cover at the end of transmission assembly.
