moparraceman
1967 barracuda fast back race car roller.very solid car, with good floors,head liner,and title. 8 pt cage,car dana,488-1 pro gears,strange spool and axle,mark williams caps. Has ladder bars with mono leap set up.drive shaft loop, and drive shaft.trans cover is new alum, also trans mount is there. Frame connectors brought threw the floor with cage welded to top.fuel cell, battery box, and electric shut off. Turbo action shifter,gauges oil,water,amps,also tack.has newer 6 panel switch panel.cage mount.weld wheels older but polished up very nice.newer 14x32 hoosier slicks on 12"rims fronts are 710x15 on 15x4 rims holley blue pump with fram filter. Braid lines from tank, then aluminum to front of car.engine compartment and front end has been painted. Extras that come with car griffin radatior,electric fan, front eleplant ears,2" hooker headers that have been blasted and painted,there excellent. Also has vac u system.fiber glass hood, rest is steel.car is dark red has 1 fiber glass seat with out dated belts. Nice car do some wiring ,your motor and trans, go racing for pictures email [email protected] or if not sold will be at norwalk sept 17-19 dont miss out on this one $6500.00 pretty firn, no trades thanks 419-545-0834 mansfield ohio
