you wouldn't know where i could find the honeycomb for the headlight bezels for a 1969 barracuda? Help if you can THANKS, Ray
I love this car, I wish I had a spare 20k. :-D
This is frustrating. Some websites such as MyMopar.com and Allpar.com list the 67 H code as an HP engine with 325 hp, and to make it more confusing even MyMopar.com lists the color of the 62-69 383 as turquoise, and the 69-71 383 HP/Police as H-Orange, (calling it a High Performance variation). So if it is a 67 HP engine why do they leave it out of the color chart?I`ve never seen anything but turquoise for the engine color of A-body 383`s. I believe most all 383`s in that era were turquoise except for police cars and and some HP versions. 383`s did pick up a few hp with the change of the heads from 67-68 and a slightly taller piston but I don`t think it was as much as 45 hp, probably closer to 10-15. The 270 hp figure is probably from the 2 barrel version of the 383. It is true that Chrysler did some odd things during production so nothing is surprising.
Do you know where/what numbers on the block would tell me exactly what the engine is?In 69 the "HP" motors were orange unless it was in a car with A/C. Then it was still turquoise. Before that I think the only big blocks that were orange were hemis
you know really? ha you can go out and get a nice honda civic base model or a chevy hhr for 20 grand..or damn a 67 383 barracuda, ill take the cuda with no complaints thank you.Dang you Guys don't cut Anyone any slack do you.Looks like a 20K car to me BB A's are not cheap.I think he should get atleast 18K out of it.
Jim
I know it is a 383 and the build date based on the numbers on the front, but with no vin are there other numbers somewhere else?
I imagine I should probably check the head numbers.
My apologies for asking questions in this thread, but I needed to run with it.
LETS NOT FORGET THERE IS A SWEET 67 BARRACUDA FOR SALE.
That color is killer, nice car.
Correct blocks, brings up a question, since I have owned this I found out some info, like the blocks cast for 67 cudas were for them only, these were not available with power steering because the motor mount on the driver side is actually cast at the very front of the engine where your power steering pump would be. Also when my motor mount went bad, I was told no body made them because of that fact, I check with year one, laysons , mancini, paddock, and the people that make all the big block conversioion mounts. So I had them rebuilt. Most 383 have the mounts on both siders near the center
I will have to check to be 100% sure, the car is in my brother's barn.Questions are a good thing. Anybody that gets irritated by them needs to take a "Mother's Little Helper" and plop on the couch for a while. What exactly is stamped on the pad on the front of the block? That should tell you if it's an HP, what year car it was used in, the assembly date of the motor, and (possibly) other things like undersized crank, lifter bores, etc. Also, what is the casting date on the side of the block?
I received my build record from Chrysler today, and the H is listed as:Questions are a good thing. Anybody that gets irritated by them needs to take a "Mother's Little Helper" and plop on the couch for a while. What exactly is stamped on the pad on the front of the block? That should tell you if it's an HP, what year car it was used in, the assembly date of the motor, and (possibly) other things like undersized crank, lifter bores, etc. Also, what is the casting date on the side of the block?
H = 383-4 HP 8-Cylinder
Is this definitive proof that it was built with an HP motor, 325 horse?
