1967 Barracuda Parking Brake Switch?
MICHAEL J KLOCK
nj
Hello all!
My 67 Barracuda is missing the parking brake switch assy. I just found a NOS switch bracket, but I'm not sure how its mounted and what type of switch it takes. Can anyone post some photos of the assembly for me. I think the switch looks like a door jam switch?
Thanks in advance for any help!
Mike K
Here is a 69 setup should be the same!
Think the dash mount was backwards in that photo but when you go to mount it you will realize that! :thumbsup:
Anyone have a picture or diagram of this part installed?
Perfect thanks! Putting one back into a car that had it removed, and information is sparse.
Anyone know what that spring in the middle of the last picture is called?
You mean the rusty looking one? If so it is the overcenter spring for the clutch pedal on a stick car.
Oh, the little one, yes I guess so! That spring and springs on the cables at the rear drum backing plate mounting both dictate return.
If Eddie asks for more info, tell him it is the spring from the cable connection pin to the pedal structure box.
Here is a closer pic of one in my 69 and the connections.
