1967 Cuda FB project
Very cool idea..... cant wait to see what design you come up with. It should really update and modernize the car.
I can't believe I never saw this build before--flat out amazing build! Good way to burn an hour before getting ready for work.
Thanks!!!
That's what happens to me, I see a build that's many pages, sit and read the whole thing!
:glasses7:
Figured out where I wanted to separate the bottom of the front fenders. Took some tape and made a line where I would cut.
Also welded the seam between the lower valance and the fenders as this will all be one piece after I form the new bumper.
Started on the drivers side fender. After I made a straight cut with the cutoff wheel.
I took a piece of sheet metal 2" wide the length of my cut and put it in the slot approximately 5/8". Marked a line on the outside of the fender to follow the contour of the fender. Took it out and turned it around to make another copy. Need two, one top, one bottom. Then I took the cutoff wheel and cut on my lines. Ended up with two pieces the same.
Drilled 3 holes in the flanges for attaching bolts. Put one flange in and lined it up with the outside of the fender and tacked along the top edge. Will weld this seam completely later.
Had to take the cutoff wheel and carefully cut along the bottom of the upper flange to make room for the lower flange. Put the lower piece in and used some 1/4-20 bolts to fasten them together. Then tacked the bottom flange to the bottom section of fender being careful to make sure the outside surface is really close to the contour of the top piece. I didn't have to be this precise because there is going to be a layer of foam/fiberglass over this seam. So close was good enuff. If you were doing this mod on a car with no buildup on the outside, you would take your time and make sure both surface were really close.
Today I welded together some scrap moly tubing for the front bumper support/frame. Bolted the brackets to the stock locations and went from there. After I had the main bumper support in place I took some 1/4" pencil rod and added a few supports from the bumper to the lower valence.
Now to take it back off and blast and seal it to get ready for the bumper/fascia molding. :glasses7:
Parting out a 75 Valiant 4 door. /6 auto-AC car. rusty. Only thing I am keeping is the hood and all the nuts and bolts.
I am putting an ad in the for sale section.:cheers:
Got the hood from a 75 Valiant that I can cut the under structure out to finish the bottom of my Cuda hood. So that project can move forward. Pretty much parted out the Valiant today. If anybody needs something, let me know and I'll see if I have it. :D
Nice fabrication,on the lower valance. Smooth, looks fast & mean,done right...
Spent all day yesterday hauling home 2-69 Barracuda fastbacks. They are basically parts cars. One is coming apart, lol. The other is a maybe if a guy was really committed. Get some pics later. :glasses7:
I think the blue one is a candidate for roof pieces for mine. I want to make the front and rear glass openings smaller to get rid of the huge rubber gasket. I just want to glue it in with a small rubber strip like newer cars.
The green one has a complete butterscotch colored interior with buckets.
More parts!!!! :blob::blob::blob:
Took 2 hours to get the green one on the trailer. It was sitting so long, all 4 wheels were rusted solid. I am wore out today...............:protest:
Now this gets me excited! - Taking the time to fabricate the understructure of the hood so that it looks original! - Nice touch!
I don't know how I missed this build.
Great fabrication, I will be watching this build
Like this?
Even the '67-'69 'Cuda parts cars,are up there pricewise. Miss my '67 Notch,time (and money )will tell.
The blue one is sooo rusted, when I went to pick it up with the forklift, the whole floor caved in. I will cut the roof off and save anything that is worth something. The rest is just rust, literally. lol
The green car has a 8&3/4 rear in it!! WOOOO HOOOOO!!!!
btw, where did they hid the build sheets in these?
Hey I am a long time lurker, that is trying to take in what all you guys are doing. I was wondering if you didn't need the third member and was interested in selling it could you PM me a price cause I need one for my build. Thanks, your Cuda is BAD A$$ by the way very cool.
Brad
Brad
Which third member? The 8&3/4 A-body I will hold on to. Just in case. :D
