edbux
Has a 360, 727 auto trans, 8 3/4 rear with 3.23 gears. Bottom end has less than 1k miles on overhaul. Has later Magnum heads, air gap intake, Holley 670 Avenger carb, custom electronic FBO ignition, Comp cam. Front end redone and converted to disc brakes. There has been much more done.
This car is not a basket case or rust bucket. Has one spot of rust and can be easily repaired. Also, driver's side door striker needs fixed.
It will need body work and paint.
More info and pics available at:
http://myweb.cableone.net/ebuxton/index.html
Feel free to look and ask questions. $3500 OBO
Located in Caldwell, Id (near Boise)
