big block scott
Active Member
1967 Dodge Dart GT , Silver Metallic body with black vinyl top , Dark Blue Metallic upholstery . Freshly rebuilt 1968 - 383 HP block with a 10/10 steel crank and standard size flat top pistons . Rebuilt 727 contains Kevlar clutches and shift kit , new convertor all controlled by a pistol grip , console mounted shifter . Rebuilt Posi 3.73 gears with 14" Magnum 500's and BFG T/A Radials . Power front Disc brakes , Under dash A/C vents with controls in custom dash , six gauge instrument panel and a six speaker stereo system that has Blue - Tooth , so you can synch up your phones playlist or answer phone calls hands free . New Sanden A/C compressor hidden with Buchllion Performance mount kit under Alternator and hoses routed behind wheel wells . 120 Amp. , one wire Alternator conversion,MSD Ignition control coil , MSD Blaster coil , Firecore Billet Distributor and Wires , Holley 4 barrel on Edelbrock Performer Intake , Aluminum 26" Radiator , High Torque Mini Starter , Optima Battery mounted in trunk ,
Located in Ocoee , Fl. (west side of Orlando) Please PM and call to make an appoint to view . fresh resto @ only $32,500 Thank You , Scott
