big block scott
Active Member
This is a lovingly restored 67 Dart GT , Beautiful metallic silver (AA1) paint complimented by black vinyl top and black tail stripes . Under the AAR six -pack hood is a 1968 - 383 HP that has just been rebuilt , features include - std. flat top pistons , 10/10 steel crank , mild Comp cam , 906 heads , MSD ignition controller , Firecore billet distributor and Firecore 8.5 mm wires , Holley Avenger 670 mounted on an Edelbrock Performer intake and feed by a Holley blue pump with pressure regulator and gauge , new fuel tank , Schumacher tri-y headers dump into a 2 1/2" "H" pipe dual exhaust with correct tips . Buchillion "hidden" A/C brackets put the sanden compressor below the 120 amp one wire alternator , new 26" aluminum radiator with dual electric fans , high torque mini starter . The 727 also just rebuilt with Kevlar bands and clutches , shift kit , new convertor and a remote oil cooler , all controlled by a pistol grip shifter . The new driveshaft and u-joints hook up the power to a 3.73 ratio , posi locking rear axle . 14" magnum 500's and BFG T/A radials complete the drivetrain . The original GT interior color is dark metallic blue upholstery with black carpet and headliner all redone with new , A custom made dash holds six gauges , A/C controls and a blue-tooth six speaker stereo so you may synch your playlist or answer phone hands free . The dash and console have carbon fiber accents for a modern feel .The trunk is nicely carpeted and hides an Optima battery behind a side panel . All of the trim is original , stainless has been polished , all other trim along with rocker moldings , aluminum grill and tail panel have been recently aluminized to appear as new . Price is Only $ 25,000. firm .
This beautiful car is located in Ocoee ,Florida just west of Orlando and near the turnpike / 429 and hwy 50 . Please PM to make an appointment to see , Thank You , Scott .
