1967 Dart GT rear panel
67_Slimer
Real Hot Rods don't shift themselves.
USA New England
I finally purchased a rear GT panel for my 67 dart and I'm just checking on installation. Is there drilling involved or do I use the existing trim? I attached a picture of the rear trunk to help with information. Thanks for any help in advance.
Uses the same trim as you have around the panel, fits under the trim so no drilling needed...
There are 4 small screws near each corner.
Hidden by the surround trim.
Thank you for the Awesome picture and information! So I would need to purchase the 4 screws needed for this. Much appreciated to all that helped!
I forgot about the 4 screws that hold it on while you put the trim around it. They really aren't needed but they make sure the panel is in the correct orientation...
I will have to see if they sell them at classic or year one. thank you!!
You can get small screws at the hardware store. Get stainless steel for a rust free future.
A pan head, truss or round washer screw would work.
The screws that hold the wheel opening trim on might work too
