3-hotrodder
New Member
hey guys. I have a 68 340 motor with a 2531915 intake. Does anybody know what carb I need for this intake? Carter AVS doesn't work, secondary plates hit. Does it use a Holley? If so what size?
OK, i'll check into that. My friend is doing a 69 GTS with 340 and that manifold has larger secondary holes. Not sure of the casting # on his. Did those motors come with Holleys on them in 68? thanks for your input.
OK, mum's the word. The hunt is on for the 2 68 carbs.Thanks for the help. My first Mopar project, treadin new ground here.
Yes, I have 1915 intake. All 4 holes are same size. Cartes AFB won't work. My uddie's 340 has AVS and secondaries are bigger so it won't bolt up. There must have been a AVS that had all same size throttle plates. This has been frustrating as heck and I'm about ready to scrap factory intake and put a performer RPM on it.
