1968 Barracuda 383/4spd
Electrical and Ignition
  1. vesparex
    vesparex New Member
    3
    0
    Nov 20, 2020
    Denver
    Local Time:
    2:27 PM
    I have an oil pressure indication issue.
    Mechanical test confirms oil pressure. Done.
    Ground grey wire unhooked from sender and turn key on, gauge sweeps smoothly to high then fluctuates, I assume the fluctuation means that the voltage reg is working.
    Multimeter at terminal end, key on, unhooked from sender, moves to 4-5v, again, fluctuating.
    Sender (for dash gauge, not idiot light) grounds fine to the engine and body with a continuity test.
    Sender (new) ohms test shows 19-22 at idle.
    But put it all together and dash gauge doesn't move. All other gauges operate, temp, fuel and amp. All operating.
    What am I missing?
  2. jaws
    jaws I put the fun in dysfunctional FABO Gold Member
    3,884
    2665
    Sep 11, 2006
    Strasburg Colorado
    Local Time:
    3:27 PM
    Line 3 if you unhook the wire and the gauge moves, you have a volt bleed somewhere. Do you have a 68 service manual?
  3. vesparex
    vesparex New Member
    3
    0
    Nov 20, 2020
    Denver
    Local Time:
    2:27 PM
    [QUOTE="jaws, post: 1973220409, member: 3343"[ Do you have a 68 service manual?[/QUOTE]
    No, I do not.
    Duane
  4. Demonracer
    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
    4,403
    2356
    Jan 31, 2010
    Cleveland, Texas
    Local Time:
    3:27 PM
    Get you a FSM, they can be downloaded for free on several sites.
  5. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    19,996
    7600
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    3:27 PM
    The temp gauge and the fuel gauge are both powered up by the same dash-gauge regulator. That regulator is just an on/ off switch with a heater in it. When powered up, all it does is continuously turn on and off, in a duty cycle that accomplishes an average of about 5 volts. The factory gauges are so slow that they rarely catch the fluctuating.
    Of course the oil-pressure sender has to vary it's ground resistance with changes in oil pressure, to make the gauge work...
  6. vesparex
    vesparex New Member
    3
    0
    Nov 20, 2020
    Denver
    Local Time:
    2:27 PM
    I found a 1967 FSM for A Bodies this weekend and read through the cluster/gauge portion, repair and trouble shoot portion. Did not see anything about how to check for voltage bleed.
    Can someone give me a little insight?
    D
    • Disagree Disagree x 1
    • AJ/FormS
      19,996
      7600
      Jan 19, 2014
      Local Time:
      3:27 PM
      Put an analog ohmmeter across your oil pressure sender to ground. Take a reading with engine off, then watch the needle and start up the engine; the needle must swing . And must not go to open-circuit, nor to full continuity. The actual numbers are less important than, than the actual swing.
    • RedFish
      RedFish Well-Known Member
      24,697
      3162
      Sep 5, 2007
      Local Time:
      4:27 PM
      sender with oil pressure shows 19 to 22 ohms. that should move the needle to about middle of range/gauge screen. Shorting the wire to the block is zero ohms test. That can make a faulty gauge do what normal the 80-10 ohm signal would not. Zero ohms should take the needle to its max position and hold it there. A fluctuation is not normal. The beam should not heat and cool fast enough to fluctuate the needle if the limiter is working properly.
      What I would do... short the temp sender wire to the block. If this needle fluctuates also, the limiter output is the problem.
      Your fuel gauge has a slither of metal on its backside that sits on a unpainted spot in the housing. This provide ground path for the limiter. A few owners have found a poor contact here to be the problem.
      • Thanks! Thanks! x 1
