Rocky_JS
'cuda
New one added to the corral. Car is all there. radiator, exhaust manifolds, 383-s hood louvers are cherry, oil pan 893, even the dip stick and fan are correct. shield is still on the prop valve. All the gauges even work.
Fuel system issues after sitting since 1990. I hooked up a make shift fuel system and put an accelerator pump in the carb. Added battery cranked it over to get oil pressure primed the carb, cranked twice and it fired back to life!
