famous bob
mopar misfit
A lot of chaos in my world the last fifteen years.
Back to slowly picking at it. Right now at a point where I have to make my own parts.
cool, I`m never buy ,what you can build guy anyway...
I've never heard of such a thing as this "hydraulic clutch pedal assembly" but I guess since I was converting a manual transmission setup and the only "change" was changing the throwout bearing from mechanical to hydraulic, and the parts involved in the conversion, I was only looking at the pathway that is commonplace.This was a bit of an adventure.
Bought a Malwood hydraulic clutch pedal assembly.
Went to install it and there was not any space between the pedals. Got a hold of Malwood tech support. Their Mechanical Engineer Ross and I did a facetime call and went over all the details. He sent me a new assembly with a few changes. Worked out great!
I really like this assembly with the little I know about it, as it appears to be straightforward and takes some of the variables out of the equation.
Kudos on top of the continuous string of accolades in the details of your work.
they were not very common to begin with. last one I had I sold in 2006. Some folks get B-body rears and move the spring perches, if you are doing ‘73 up front discs this may work better and allow you to run same wheel front and back. I had Dr Diff make an axle housing for me that was narrower than the A-body axle and had new billet axles and disc brakes.Un-realated question, any one you know over there have an A Body 8 3/4 rear for sale?
Thanks. I am down here in Midlo with a busted 7 1/4.they were not very common to begin with. last one I had I sold in 2006. Some folks get B-body rears and move the spring perches, if you are doing ‘73 up front discs this may work better and allow you to run same wheel front and back. I had Dr Diff make an axle housing for me that was narrower than the A-body axle and had new billet axles and disc brakes.
