1968 Dart /6-904 > 440-727 Swap
Tacfire11
Strike Hard, Strike Deep
Philadelphia, PA
I need your help guys, I haven't mated the transmission to the motor yet, but was curious if the original Transmission Cross Member (originally a Slant 6 & 904 Tranny) will bolt up to the 727? I've read that they both used the same cross member, but figured I'd ask before I start dropping this in and get disappointed when it doesn't bolt up. Oh, BTW the 727 has the long tail Cone, not the snub nose.
Thanks
Pat
Yes it's the same crossmember and in the same location for either trans , you'll need a shorter driveshaft .
