1968 Dodge Dart
Very impressive. .....I knew you stripped it, but no idea the amount of work (and $$$) done to it afterwards. Major difference for Bout from when he saw it several years ago. OMM and I stopped by Bouts the other day and the Flash just got the fenders and doors primed. I would guess it will be in paint by Christmas. Then it is your turn.
Nice job on the Dart.
TREMENDOUS. STUPENDOUS. MARVELOUS. EXCITING!!!
I'd like to see some details on your Hilborn stuff. I recently scored (I'm sure you know) a rare Hilborn intake manifold. My stacks may have been cut, they are straight/ parallel, with no bells
What are you using for the injectors/ distribution setup, how do you have the MAP reservoir setup, trigger, etc?
Before I tore mine down for paint I had Holley HP EFI, and also recently bought a Megasquirt kit.........mostly for education LOL
I sent my intake to Fox Engineering for the conversion. I'm thinking the injectors are 50lbs but I would have to find the paper work, It's been years that I had that done.
I'm excited to have Bout finish the body work. I know it will be done right.
Thanks. Mine will have to be "considerably" more back yard / shade three than that LOL
I needed to add buttons to the dash to start the car and I ordered a few from Billit Buttons.
the cost of a couple of overpriced buttons....several hundred dollars
the grin on our faces........priceless
I think I nailed it.
Very cool Mark! I've been waiting to see this build since you told me about it when i bought the 8 3/4 from you in the spring. looks like you made enough room to fit those huge wheels and tires you wanted to run lol
I hope the 8 3/4 worked out for you. Oh yeah, those 31 inch tall tire fit just dandy!
well, as you know a lot of not so glamorous work is happening now. Wiring, planning, running wire twice.....Im going to pull the fuel tank tomorrow so Tod can make a wiring harness for it. I bought a bunch of modern wire end connectors so that if needed most components can be un-plugged and removed.
just stop by to check on the Flash.....1/2 way thru the long board
better get busy... you are on deck
No pressure....enjoy the ride
Merry Christmas my friend.
Denny
I could have just used a rubber hose but.......
I used a AN fitting and a brake line. Just had to file down the flare and re drill the nut. A couple of rubber grommets and thats it. A little buffing and then clear.
