76orangewagon
Here is a 1968 Dodge Dart built to run in the Hemi Super Stock Class. Quality parts used throughout the entire car, original solid Steel body and roof, doors are also steel (but lightened) Fiberglass hood, fenders, trunk and bumpers. Here is a break down of a lot of the parts included..
-Currie 9" housing back braced with nodular center section with spooled
4:10 gears.
-35 spline Moser Axles with Large bearings.
-S&W 4 link with QA1 Adjustable coil over shocks
-Wilwood 11.44" Dynalite rear brakes and 10.75" Dynalite front Brakes.
-Goodyear 33"x 15"x15" rear slicks and Moroso 26"x 4.5"x15" front tires.
-Weld Wheels.
-Magnum Force Adjustable upper control arms.
-RCI Aluminum seats with padded sea covers.
-Lexan Glass.
-Northern Aluminum radiator with electric fan.
- MSD 7 AL-2 Ignition Box.
-Powerglide case with JW bell housing and Flexplate.
-JAZ Aluminum fuel cell.
-Stroud spring loaded Parachute.
-QA1 Adjustable front shocks.
This Dart is been scaled at #1540 lbs without motor and transmission and
is build to be certified to an 8.50 index.
I am Listing this for a friend, so please contact him for all questions .....his name is Tom the car is located in Cuyahoga Falls, Ohio and listed at $ 16,000.00...Lots of extra parts included but not listed
4:10 gears.
-Weld Wheels.
-Lexan Glass.
