lostland
unregistered
1968 notchback barracuda,
The engine is a completely rebuilt 360 cu.in. and done at .030" over stock. Fitted with an H-272-2 grind cam, "j" Heads, MSD 6A Ignition system, Taylor 8mm. spark plug wires, Edelbrock air cleaner, rocker covers and 4 bbl. intake manifold have been installed. The rad is new with extra cores, a chrome alternator and an S.S. flex fan.
Walnut wood Grain three spoke steering wheel,factory floor shift,a 3 speed 727 auto transmission with a shift kit installed and a 8.75" posi. rear end and 3.55 ratio gear set and dual exhaust with Flowmasters.
No rust at all,no dents some buffable scratches.Needs a good detailing.
Car had a full rotisserie done and has always been stored inside.Never seen anything but warm summer days.I can store it free till spring if need be.Everything works great.Turn key and big time go.
Port Perry,Ontario Canada.Serious enquiries only.
$15,000 firm
Call Brian (905)260-7775
$15,000 firm
