69CudaFan
Not that some of these are specific to a 440 'cuda, but the car deserves the best correct parts.
Here is the list:
Straight front license plate bracket and mounting hardware
Hi and Low Horn Assemblies with brackets and mounting hardware that function!
2949065 Radiator (longshot)
Correct radiator shroud mounting hardware
2875758 Single Point Distributor (rebuildable core)
2095150 starter (should end in 8)
2892091 727 Transmission OR 2892093 727 Transmission or case with a blank VIN pad. Four digit date should range between 3000 and 3047 on driver's pan rail. (this would be a LONGSHOT). If someone had 9B236779 in the greater Greenville, IL area, I would pay handsomely!
Unique 440 kickdown linkage, or pics and dimensions so I might have someone fabricate a replica.
Correct Jack Assembly and spring to hold in place (no lugwrench necessary)
Also need the Emergency Brake handle assembly under the dash, and the associated mounting hardware.
I will add more as needed. Email contact is best. [email protected]
Here is the list:
