[SOLD] 1969 440 HP 700 hp Pump Gas
davescuda
Cheshire, CT
1969 440 HP block
Built By Comp U Flow
520 pump gas E Z Heads
Built for the street
Dyno over 700 HP with sheet
Torque 650
Dyno time only
10.6 to 1 with aluminum heads
Long list of parts all good stuff and work done
14,500 invested
14.500 or best offer
only reason selling is I change direction in my 68 Barracuda Installed a 604 Hemi
It was going into an a body with factory mounts
Back on track, bumping up for our member @davescuda after cleaning up this thread.
Good luck on your sale of this big block power house sir
I know I am not going to get the 14500 for it. So make me an offer. No low balling I don't need to sell, I do have the Mopar disease so I may just buy another car. Anybody have a nice clean Roller.
1969 440 from a GTX full Vin on block
magnaflux and all that stuff
open up oil passages
40 over
line hone squire decked
bored with block plates
eagle crank stroke 4.375
eagle rods 7.1
custom ross pistons
rings c&a
clearance block
fluid damper balancer
balanced rotating assembly
studied mains
oil pump indy max
cam shaft custom solid roller comp 698
comp roller lifters
timing chain billet tour.
stroker windage tray
milo pick up
pro fit rear seal
bronze gear
ez head kit
up graded plate
ported, but not maxed ported. flow 305 int and 217 exhaust
up graded valve string 943
up graded 10 ' locks and titanium retainers
pro fit seals
H sharp 1.6 rockers
custom push rods
assembly, clayed, cam degree
m1 intake with work done to it. nick sail with the work done to this intake he get more out of it than the victor. A lot of work done to the intake
welded up plenum, plenum work matched to the two inch indy adapter with work, port matched
1050 AED Tuned to this motor then fine tuned on dyno
indy valve covers
morso breathers
Charlies custom oil pan
Mopar race gasket set
indy adapter
MSD distributor
Dyno with sheet
Head flow sheet
I may have left something out
This is a bad *** motor and its not even maxed out.
This motor was built to drive on the street and go to the track once or twice a year. The only reason I am selling it is because I bought a 604 Hemi off my buddy to go In my 68 Barracuda.
I have way more into this, my loose your gain
11,500.00
Dave, If your interested and serious about a done roller , pm me. Mines apart for a few weeks after damaging some stuff (engine) at Lebanon Valley (first pass right after talking to you). I've been kinda disgusted with the whole thing and considering cleaning house. With the HDK front end ,just change the mounts to BB. Keith
WOW thats a bummer. Pm me how much you want for it.
That's a great deal, I have more than that in my 434" small block build.
