1969 barracud 340-S tube car (project)
chad67gtdart
Member
Rating - 0%
0   0   0
THIS IS A 1969 barracuda 340-S tube chassis project car, Chris Alston chassis with ladder bars, rack & pinion, Strange front coil-over struts With disc brakes & calipers, Strange rear coil-over shocks. Comes with 83/4 rear with shock & ladder,& wheelie bar, brackets welded on. 489 case with 5:13 gears in a clutch type posi unit ( less than 10 passes on gears & unit since new, tested in another car). Stock axles(5x4) with long studs, new brakes & hardware,new brngs. Comes with radiator,trans. cooler, 1 seat,small fuel cell & wheelie bars. The car , original 340-S 4 speed car, with Title ,if you want to build a street rod . Has been completely cut out, needs all metal work(floor pans, wheel tubs, etc.) Hood & trunk is one (1) layer, with pins . I have all the chrome, front & rear bumpers,tail lites, & the highly sought after S emblems & fish. The doors are un-cut original cond. w/ the glass intact. (no other windows) Front clip is in great shape, so is grille . The car is, as I said one (1) layer , very lite. No rust holes,or major crash spots, body is straight & solid. THIS IS A PROJECT, NOT A COMPLETE CAR!!! I'm sure I have a few more parts that go along with it that I can't think of now. Located in south central Virginia 50 miles south west of Richmond,Va. In Crewe,Va.23930 ASKING $5000.00 OBO or will trade for R model smallblock , or parts for same. (chassis is not rusty , thats red oxide primer) :burnout:
